First post, by skwatter
Hello
I'm trying to get my cdrom version of Star Wars: Dark Forces to run in dosbox on my windows xp computer. I have the actual cd rom (not a downloaded copy). the game is installed correctly on my computer.
i have read many faqs on mounting cd drives but nothing has worked for me. my cd drive is e:\. if it matters, the installed directroy of the game is c:\dark.
i put the cd in the drive (e:\) and fire up dosbox (0.72)
i type:
mount d e:\ -t cdrom -ioctl
and it says
mscdex installed.
drive d is mounted as CDRom e:\
i don't know what to do beyond this point. did i miss something or do i have to do more?
please help. i want to buy "under a killing moon" and would like to know how to get cdroms to work in dosbox.
Reply 2 of 14, by MiniMax
Rank Moderator
Moderator
Did you read my 60 seconds guide?
_________________
Reply 3 of 14, by skwatter
how could i do that?
could i just access the cd from my computer, click and drag the install.exe to dosbox?
i have trouble understanding the 60 second guide.
Reply 4 of 14, by skwatter
if my cd drive is e:\, do i have to put it as d:\ like the 60 second guide says?
because d is my archival hard drive isn't it?
Reply 5 of 14, by skwatter
ok i i did exactly what the guide said, but step 5 says that the prompt needs to be z:\
my prompt stays as c:\ hence the last step in step 4.
how can i change it back to z:\? do i have to mount another drive?
do i have to quit dos box and start all over?
also, it says that mounting c:\ is not recommmended. please mount a subdirectory next time.
what should i do? 🙁
Reply 6 of 14, by skwatter
in step 5, is d: refering to my cd drive?
should i change it to e:?
i'm clueless
Reply 7 of 14, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
do exactly the same again. You did not do step 1 and step 4 exactly if Dosbox tells you that mounting c is not recommended.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 8 of 14, by Dominus
DOSBox Moderator
No. Once you've done the mount commands in 4. the only drives you have IN Dosbox are c:\, d:\ and z:\
Reply 9 of 14, by MiniMax
Rank Moderator
Moderator
Thanks for spotting that error skwatter. I have changed the text so it now correct shows C:
Please try again.
what should i do? 🙁
That warning only comes up if you do something like this:
mount C C:\
If you do a mount C "C:\some\directory" you will not get the warning.
_________________
Reply 10 of 14, by skwatter
i got it to work!
now if only under a killing moon could be this simple.
i have to switch cds in the middle of game play!
to do that i would play the game until i needed the next cd, then i would insert the next cd, then i would go ctrl f4 and that should do it?
Reply 11 of 14, by MiniMax
Rank Moderator
Moderator
Yes. If you want to take the CD swapping to the next level, then you can create copies (BIN/CUE images) of the CD's, save the images to your hard-disk, and use the imgmount to mount them with. Then you don't need to physically swap the CD's, just hit Ctrl-F4 and DOSBox will use the next image.
_________________
Reply 12 of 14, by skwatter
ok, i got under a killing moon.
now i need to install it in dosbox. i have all the files in iso format.
how would i mount them with imgmount?
Reply 13 of 14, by collector
It's in the README.
Reply 14 of 14, by skwatter
ok, i installed the game and got everything working perfectly, sound, graphics, everything. i did it in a different way then what you guys said, though.
i just took the isos i made and mounted them in a virtual drive, (daemon tools, alcohol 120%) and set up the drives that daemon specified in dosbox. i didn't use imgmount at all, and to change cds, i just mount the next iso in the j:\ drive on daemon tools, and the game itself automatically starts it up.
