First post, by Knipfy
Hi, I'm new here and wasn't sure if this was the right place to ask. I'm trying to get my config settings up for I. M. MEEN and whenever I choose any of the settings it says "ERROR Could Not Save Configuration File". I'm confused as to why this is happening.
I currently have I. M. MEEN installed on my computer and I played it before I even found out about DOSbox. This includes my CD which is required to play this game and I also have folder called MEENDATA on my C drive which only has my saved games on it and a few other files, (CD has MEEN.exe and INSTALL.exe). Is there any solution to correct this?
Here's my System Specs just in case:
Windows XP SP2
256MB RAM
Intel P4 Processor 2.0 Ghz
Thanks, I hope I can finally hear and play I. M. MEEN again the way it's meant to be played!
Reply 1 of 5, by MiniMax
Rank Moderator
Moderator
Did you try a fresh install of the game from inside DOSBox?
It should work:
http://www.dosbox.com/comp_list.php?showID=35 … r=I&search=MEEN
Re: I. M. Meen audio problems
http://games.multimedia.cx/im-meen/
_________________
Reply 2 of 5, by Knipfy
I didn't try that but I have to type "install" after I mount the CD-Rom drive and it brings up the Configuration file. I already do have the game installed and I don't want to remove it with the fear of never being able to play it again.
Reply 3 of 5, by MiniMax
Rank Moderator
Moderator
That is the beauty of DOSBox!! You simply give it a fresh folder to install into, and it won't touch your current install.
60 Seconds Guide to DOSBox.
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
_________________
Reply 4 of 5, by Knipfy
Thank you so much!!! I just started it with full sound and music! I can't get full screen to work though, I received an error after I pressed ALT-ENTER. Any way to fix this? Again, thank you so much!
Reply 5 of 5, by MiniMax
Rank Moderator
Moderator
What was the error message?
_________________
