First post, by gaz6699
i had dosbox working with Alien Logic for 2 days now wheni run it i get an error
my conf file has the following set at the end to mount and load the game
[autoexec]
# Lines in this section will be run at startup.
mount c D:\games\Dos_Games
imgmount d "d:\games\Dos_Games\alien\cd\alien-cd.cue" -t iso
c:
cd alien
alien
this game has 1 data track and 5 audio tracks
and this worked fine for 2 days or so
then whist i was trying to set another game up in the same way "phantasmagoria" i was having trouble getting it to run so to check everything over i ran alien logic and that now wouldent run either
if i change my conf to load the bin it loads fine but then crashes when it trys to play the aduio track
the cue file just failes to mount with the following error
could not load image file d:\games\Dos_Games\alien\cd\alien-cd.cue
MSCDEC: Failure: Path not valid
the path is correct i have checked several times and it did work originally i havent changed the conf file since i got it to work
i have a separate conf file for each game i am compleatly lost why this has stoped working
iv tryed reinstalling dosbox but has made no diffrence
