First post, by Mike 01Hawk
- Member
It's ALWAYS SOMETHING!!! 😠 😠 😠
Sound Devices:
1) SB16 (w/ DB50xg attached)
2) MPU401AT (w/ SCB-55 attached, as well as controller for the MT-32, which is sound device 3)
4) Ensoniq SS
Speakers: Logitech Z-5500s which have a 3.5mm jack input
Well, I THOUGHT I'd be golden with these 2plug->1jack cables... http://www.monoprice.com/products/product.asp … &seq=1&format=2
Get a few of those and have everything goto the 1 run of 3.5mm cord to the Z5500.
Turns out that the SB16 doesn't play nice w/ the MPU401-AT if they're both hooked up at the same time.... it diminishes the SB16 sound level as well as quality.
SOOO.... what's a good 4-in 1-out 3.5mm mixer that won't send power from one line back up the line of the other input device, which is what I'm assuming is happening here and causing issues.
Thanks guys
Mike
Dell Optiplex Gxpro: Built solely so I could re-live my SB16 days properly with newly acquired sound pieces: MT-32, SCB-55, and DB50xg 😀
