First post, by GFawkes
I bought Glidos a while ago to use with TR1 and unlocked it without trouble.
All was well until i upgraded my O.S. From Windows Vista Home Premium to Windows Vista Ultimate. The Glidos ID changed, so Yesterday (I think) I unlocked again and all was well - not totally suprised. However, I switched on again today and I notice the id has changed again and i have no more unlocks.
I did notice the following:
VDOS and Glidos now need to be run as administrator. They weren't before.
I set the permissions on the Glidos folder to Full access and Vdos no longer needs to be run as admin.
Hope you can help.
I have a newish Sony Vaio VGN-FZ31S 250GB, 2MB running Vista 32 Ultimate (Premium before). I use it for TR1.
Reply 1 of 5, by Glidos
Similar problems have been fixed in the past, so make sure you are using v1.41. If you already are running that version then post the results from running MIBTest.exe, which you can get from
this post. Run it twice, with a reboot in between and post both sets of results.
And you'll need more unlocks on your account, so let me know your account email address by private message.
Reply 2 of 5, by GFawkes
Here are the results from the utility before and after a restart. I am running 1.41. I'll send a private message for the unlocks.
Thanks in advance.
GlidosID: 2CE9EC95348F7CA88663FB7449CDCF85
[0,24] (Software Loopback Interface 1)
[1,131] (WAN Miniport (L2TP))
[2,6] 8C-BA-20-52-41-53 (WAN Miniport (Network Monitor))
[3,6] 8C-BA-20-52-41-53 (WAN Miniport (IP))
[4,6] 90-19-20-52-41-53 (WAN Miniport (IPv6))
[5,23] 33-50-6F-45-30-30 (WAN Miniport (PPPOE))
[6,131] 50-50-54-50-30-30 (WAN Miniport (PPTP))
[7,131] (WAN Miniport (SSTP))
[8,6] 00-1A-80-A3-40-00 (Marvell Yukon 88E8036 PCI-E Fast Ethernet Controller)
[9,6] 00-16-B6-70-DE-1F (Gigabit ExpressCard Adapter)
[10,71] 00-1D-E0-CA-B3-2F (Intel(R) Wireless WiFi Link 4965AGN)
[11,23] 20-41-53-59-4E-FF (RAS Async Adapter)
[12,131] 02-00-54-55-4E-01 (Teredo Tunneling Pseudo-Interface)
[13,6] 90-19-20-52-41-53 (WAN Miniport (IPv6) - WinpkFilter Miniport)
[14,6] 8C-BA-20-52-41-53 (WAN Miniport (IP) - WinpkFilter Miniport)
[15,6] 8C-BA-20-52-41-53 (WAN Miniport (Network Monitor) - WinpkFilter Miniport)
[16,6] 00-1A-80-A3-40-00 (Marvell Yukon 88E8036 PCI-E Fast Ethernet Controller - WinpkFilter Miniport)
[17,6] 00-16-B6-70-DE-1F (Gigabit ExpressCard Adapter - WinpkFilter Miniport)
[18,6] 00-1D-E0-CA-B3-2F (Intel(R) Wireless WiFi Link 4965AGN - WinpkFilter Miniport)
[19,1] (Bluetooth Device (RFCOMM Protocol TDI))
[20,6] 00-1E-3D-39-EE-00 (Bluetooth Device (Personal Area Network))
[21,6] 00-16-B6-70-DE-1F (Gigabit ExpressCard Adapter - WinpkFilter Miniport-QoS Packet Scheduler-0000)
[22,131] 00-00-00-00-00-00-00-E0 (isatap.home)
[23,6] 90-19-20-52-41-53 (WAN Miniport (IPv6) - WinpkFilter Miniport-QoS Packet Scheduler-0000)
[24,6] 8C-BA-20-52-41-53 (WAN Miniport (IP) - WinpkFilter Miniport-QoS Packet Scheduler-0000)
[25,6] 8C-BA-20-52-41-53 (WAN Miniport (Network Monitor) - WinpkFilter Miniport-QoS Packet Scheduler-0000)
[26,6] 00-1A-80-A3-40-00 (Marvell Yukon 88E8036 PCI-E Fast Ethernet Controller - WinpkFilter Miniport-QoS Packet Scheduler-0000)
[27,71] 00-1D-E0-CA-B3-2F (Intel(R) Wireless WiFi Link 4965AGN-Native WiFi Filter Driver-0000)
[28,6] 00-1D-E0-CA-B3-2F (Intel(R) Wireless WiFi Link 4965AGN - WinpkFilter Miniport-QoS Packet Scheduler-0000)
[29,131] 00-00-00-00-00-00-00-E0 (Microsoft ISATAP Adapter #3)
[30,131] 00-00-00-00-00-00-00-E0 (Microsoft ISATAP Adapter #2)
GlidosID: 7D73E835EF214DCDA35897CBF23EED25
[2,6] 10-3C-20-52-41-53 (WAN Miniport (Network Monitor))
[3,6] 10-3C-20-52-41-53 (WAN Miniport (IP))
[4,6] 10-3C-20-52-41-53 (WAN Miniport (IPv6))
[13,6] 10-3C-20-52-41-53 (WAN Miniport (IPv6) - WinpkFilter Miniport)
[14,6] 10-3C-20-52-41-53 (WAN Miniport (IP) - WinpkFilter Miniport)
[15,6] 10-3C-20-52-41-53 (WAN Miniport (Network Monitor) - WinpkFilter Miniport)
[21,131] 00-00-00-00-00-00-00-E0 (isatap.home)
[22,131] 00-00-00-00-00-00-00-E0 (isatap.Skynet)
[23,131] 00-00-00-00-00-00-00-E0 (Microsoft ISATAP Adapter #2)
[24,6] 10-3C-20-52-41-53 (WAN Miniport (IPv6) - WinpkFilter Miniport-QoS Packet Scheduler-0000)
[25,6] 10-3C-20-52-41-53 (WAN Miniport (IP) - WinpkFilter Miniport-QoS Packet Scheduler-0000)
[26,6] 10-3C-20-52-41-53 (WAN Miniport (Network Monitor) - WinpkFilter Miniport-QoS Packet Scheduler-0000)
[27,6] 00-1A-80-A3-40-00 (Marvell Yukon 88E8036 PCI-E Fast Ethernet Controller - WinpkFilter Miniport-QoS Packet Scheduler-0000)
[28,6] 00-16-B6-70-DE-1F (Gigabit ExpressCard Adapter - WinpkFilter Miniport-QoS Packet Scheduler-0000)
[29,71] 00-1D-E0-CA-B3-2F (Intel(R) Wireless WiFi Link 4965AGN-Native WiFi Filter Driver-0000)
[30,6] 00-1D-E0-CA-B3-2F (Intel(R) Wireless WiFi Link 4965AGN - WinpkFilter Miniport-QoS Packet Scheduler-0000)
Reply 3 of 5, by Glidos
Try this new Glidos.exe. Replace your current one with it by copying it to C:\Program Files\Glidos, or whereever else you installed Glidos.
    Glidos.exe
    504 KiB
    739 downloads
    New Glidos.exe v1.41a. Improved unlock stability on Vista
Reply 4 of 5, by GFawkes
That's great. I've tried rebooting a few times now with the new exe and all is well.
Thanks.
Just thought i'd mention that I do have to unlock Vdos after every reboot, although that's not really a problem.
