First post, by rombell
During installation, it fails after asking the path and before actually creating it.
It shows a window with such a message:
Internal Error 2203. C:\WINNT\installer\3a400ef8.ipi, -2147287035
then it shows "Installation Incomplete" window and that's all.
MSI version 2.00.2600.2
Windows 2000 SP3
Any suggestions, please
Reply 1 of 2, by Nicht Sehr Gut
Originally posted by rombell During installation, it fails after asking the path and before actually creating it.
Internal Error 2203. C:\WINNT\installera400ef8.ipi, -2147287035
Appears like you have a "permissions" problem:
http://support.esri.com/index.cfm?fa=knowledg … cleShow&d=24089
or that the MSI file was read-only:
http://support.microsoft.com/?kbid=296056
Reply 2 of 2, by rombell
Thanks!
I just found the solution.
In my system I always set TMP and TEMP environment variables to C:\TMP
Under W2K must be directly assigned FULL ACCESS for SYSTEM for the catalog
