Music out of tempo and crackles in some games (this case it is LSL3&2)
First post, by marooned_on_mars
I get this problem using the Munt Win32 driver. In several games I get sometimes those inconsistent tempo (recorded from LSL3) in the music while using DosBox`s midi feature with it set on "intelligent" (I tried to set it on uart but it didn`t fix my problem and it sounded strange and some instruments are muted. I tried to capture the midi commands, but that midi had the normal tempo, tho it didn`t play like in DosBox (yes, I`ve set the output to Munt in Winamp). The other problem is that some crackles appear in some cases (recorded from LSL2). I`ve also attached the recordings, no other programs/processes were running when I recorded those, other than the recorder, other midis from games play at normal tempo when recording with the exact recorder.
My system specifications:
CPU - Intel P4 Celeron D at 2.26GHz
384MB RAM
DosBox 0.71
Munt Win32 Driver 0.1.3
Is there any solution (besides using the Munt CVS?)
    problem_lsl3.ogg
    1.5 MiB
    348 downloads
    From Cheatem`s offices
    problem_lsl2.ogg
    135.21 KiB
    344 downloads
    From when the bomb explodes in the Aerodork airport
Reply 1 of 11, by Snover
Two things. One, the volume levels are not calculated properly in the non-CVS version (and they might still be bad in CVS, but the are better). Two, that is probably a too slow CPU to properly emulate an MT-32 and DOSBox at the same time. Munt is very CPU-intensive, when I last tested it on an Athlon64 3500+ it could not do both.
Yes, it’s my fault.
Reply 5 of 11, by MiniMax
Rank Moderator
Moderator
Why all the negative vibes? Be happy, there are enough people fighting already all over the world.
_________________
Reply 6 of 11, by marooned_on_mars
wd wrote:
Contribute in making it faster. It's a shame if you don't contribute, really.
If I could, I would. And I have the intention, after I learn some coding. And I did not accuse the author, I was just saying that it's a shame that I cannot emulate it properly because my computer.
dh4rm4 wrote:
Or you could stop being a tightarse marooned and go and buy a second hand real MT32 and a USB midi adaptor. It's a shame you're a tightarse really.
As a matter of fact my "thightarse-ness" did search upon those e-bays from europe a few weeks ago, and wasn`t lucky to find one (other than a LAPC-I, wich I cannot possibly do anything other than to plug into my old computer, but I`m not interested in that). It`s a shame really that you throw everywhere insults without asking first.
Reply 8 of 11, by dh4rm4
More looking, less excuses. Keep looking and eventually you'll find one. It took me quite a while.
Reply 9 of 11, by marooned_on_mars
wd wrote:
That's not a shame, and it indeed accuses the people who are/were working
hard on munt. The real shame is on you for your statement.
If it does anything good I edited the post to not cause confusion again.
I will try to keep that in mind.
