First post, by Nicht Sehr Gut
- l33t
From "thijzjuh":
when i try to play death rally... everything goes fine until the game starts, (when I see mine and other cars) everything goes v […]
(when I see mine and other cars) everything goes very slow 😖
and i can't do nothing to it to make it disapear 🙁...
ive tried to start in "dos mode" by typing command...
I'm not really sure what you mean by "typing in command". To be in "DOS Mode" of Windows 98 means Windows isn't running, just DOS.
If you start it from a DOS prompt within Windows, you're still running it in Windows.
andd in 98/ win me
mode , wont do...i'm using a p4 1,8hrz geforce 4 TI 128mb...
Did you try following the guide for "Death Rally" in the Problem Children thread? Be sure to add the /W parameter when running it within Windows.
From "cairn':
I carefully read your posts concerning this matter. I've tried NOLFB, VMDSound. But it didn't fix my problem which is : I run the program using the /W parameter, it launches, gives some error messages (about the EMM amongst others), displays "Loading music & effects, please wait...". And it stays a very long time like that. I would say it's frozen. I've searched quite a lot on the net and haven't found any info. Hope you can help me identify the problem.
Really need more info about your system, since all I know is that you're running XP. What kind of video card are you using? Also, we really need more detail on the error messages.
I would hazard a guess that you are getting "Memory Management" errors, but it's hard to say anything beyond that at the moment.
