First post, by SKARDAVNELNATE
- Oldbie
I loaded up Terminator: Rampage. BTW, it plays smooth in 0.65 but becomes sluggish in anything more recent.
The control options are rather limited. Either keyboard, joystick, or mouse. No combination of these. The problem with keyboard is that turning left or right isn't very responsive. It's like a 20 seconds to rotating 3 degrees. It's much quicker when using mouse.
The problem with using mouse is controlling forward and backward movement. Right click will propel me forward. It's a little quick but the real issue is moving back. The only method I found to back away from advancing opponents is to drag the mouse toward from me, pick it up, and repeat.
It doesn't look like there's any way to map mouse movement so that I could make it look like I'm dragging my mouse with an arrow button. I don't have a joystick but is there a way I could input one of those actions onto a key?
