keropi wrote:MOTS expansion? never knew it existed... I recently bought Jedi Knight 2, came in 2 CD's
I did a little research , and I see that the mots expansion ISO is 170MB, so no way it has audio tracks
ooh and I see MOTS comes with an engine update! groovy!
Dominus wrote:My version of Mysteries of the Sith has Audio tracks. It's the German version, though. Hmm, at least the cover and backcover of the CD jewel case is in German, it seems all the docs/readme... on the CD are in English. Been a while since I played that
I doubt that it is DX6, since if it differs from the main game, it should include the DX6 installer, which at least my version doesn't...
Mysteries of the Sith needs to have DirectX 5.0 installed to run. During the installation, you will be prompted to install DirectX 5.0 if it is not already installed on your system. You need to have your original Jedi Knight Disk #1 available to install DirectX 5.0.
Pauses in Gameplay Due to CD Music Track Change
Some CD-ROM drives may have slower track-to-track access, so when the music reaches the end of its track, there may be a pause while the music reloads. If you have experienced this problem you may want to turn off the Music option to avoid pauses in the game by going to the Sound section located in the Setup section from the main menu (or the in-game menu).
CD Audio
Please make sure that you have the CD audio cable connected correctly between your sound card and CD-ROM drive to hear music in the game. You can check this by plugging your head phone or speakers into the front of your CD-ROM to see if you hear music playing. If you hear sound from the front of the CD-ROM drive, but do not hear music in the game, then the audio cable is probably not connected and you should contact the manufacturer for assistance in connecting this cable.
Users browsing this forum: No registered users and 3 guests
