First post, by rfxcasey
Hi, problem, can't get dosbox working fullscreen in linux. I have edited the dosboxrc file and this doesn't have any effect. Can someone give or point me in the direction of instructions on how to do this.
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
alt-enter ?
ofcourse your X configuration has to have support for lowresolutions
Water flows down the stream
Reply 2 of 3, by rfxcasey
Well, see, it IS running in fullscreen its just that it doesn't fill the whole screen. Instead there is a black board about 4 inches long around the whole program. Could someone give me somewhat detailed directions on how to fix this?
Reply 3 of 3, by ripa
Switch output=surface to output=opengl, switch aspect=false to aspect=true, and switch fullresolution=original to fullresolution=1024x768 for example.
