First post, by n4bk
hello all!
ich just have installed DOS-BOX 0.73 to use old dos-software.
this software has a main folder with the program data c:\FDC_STB\
further there is a folder c:\FDC_ORD\ in which i put external data (nc-files).
now the software starts normally and should read the external data out of the folder c:\FDC_STB but this does not work.
i´ve made a directory c:\dosbox\ and put this two folders (FDC_STB and FDC_ORD) in it.
then i mounted c c:\dosbox\
can anybody help me?
when i use the "normal" dos-box from WIN-XP it works... but not with DOS-BOX 0.73 ...
