First post, by morphvox
Hi all, i have installed dosbox and i wanted to play with asterix & obelix, but the sound feels very bad, i have an acer 5738g with ubuntu 9.10, is there any solution? thanks
Always look back.
Reply 1 of 8, by laxdragon
sudo apt-get install libsdl1.2debian-pulseaudio
This fixed the choppy/chirpy audio issues in Ubuntu for me.
laxDRAGON.com | My Game Collection | My Computers | YouTube
Reply 2 of 8, by morphvox
Ok now i try it...
But, i have this problem also on windows vista...
But over this problem, is there another problem: i have some artifacts on the screen when i start to play... Any solution please? Thanks!
EDIT: The problem appears when i press alt+enter (fullscreen), the game freezes and i have to close dosbox with task manager...
Always look back.
Reply 3 of 8, by robertmo
try different output= types in dosbox's configuration
Reply 4 of 8, by morphvox
Where i can found dosbox's configuration?
And is there any configuration belonging to game?
Always look back.
Reply 5 of 8, by ripa
README.txt section 11:
DOSBox will parse configuration files that are specified with -conf. If
none were specified it will try to load "dosbox.conf" from the local
directory. If there is none, DOSBox will load the user configuration
file. This file will be created if it doesn't exist. The file can be
found in ~/.dosbox (Linux) or "~/Library/Preferences" (MAC OS X).
Windows users should use the shortcuts in the startmenu to find it.
Reply 6 of 8, by wd
Rank DOSBox Author
DOSBox Author
WOW THERES A README WTF
Reply 7 of 8, by IIGS_User
Watching this forum for a long time now, I still wondering:
WHAT is a README, at least? 😉
Still, sometimes someone needs a hint what to search for, in the readme file.
Klimawandel.
Reply 8 of 8, by morphvox
Not worked for me... The sounds still lags and feels bad...
I tried also to change output and the midi device... with no results
Always look back.
