First post, by Malik
Can anyone post some pictures showing the items used and how to remove those glued on heatsinks?
I have 2 or 3 such tall fins heatsink which I want to use on other cpus, mainly in terms of avoiding the cpu fans. All are Pentium cpus (Pentium 75 - P166MMX), with the ceramic base and one black plastic base P200MMX cpu.
(I'll try fixing a huge LGA based heatsink on a P54c or P55c cpu and put up the pictures in the mean time. I have those extra Socket 7 heatsink clips which I may somehow fix it with the bigga pappa heatsink. This is crazy, but then, it'll be cool checking out the temp.😀)
Reply 1 of 13, by Mike 01Hawk
putty knife + twist = problem solved (or, well.... cpu ruined, 🤣)
Dell Optiplex Gxpro: Built solely so I could re-live my SB16 days properly with newly acquired sound pieces: MT-32, SCB-55, and DB50xg 😀
Reply 2 of 13, by prophase_j
Throw it in the freezer. The glue will become brittle when it's cold 😀
"Retro Rocket"
Athlon XP-M 2200+ // Epox 8KTA3
Radeon 9800xt // Voodoo2 SLI
Diamond MX300 // SB AWE64 Gold
Reply 3 of 13, by Malik
Ok, let me put this in another way : Can anyone post some pictures showing the items used and how to remove those glued on heatsinks,without ruining the cpu? 🤣
Reply 4 of 13, by Malik
Here's a not so nice way of removing the glued heatsink :
No. This is not my trial.
Here's the source if anyone feels like venting anger on the person who did this to the 486 cpu! 😁 :
http://www.hard2mano.com/index.php?showtopic=12322
Reply 5 of 13, by keropi
extreme temperature conditions... I would pick the freezer though ...
Reply 6 of 13, by retro games 100
The person boiling this CPU is not serious, because if you look at the pins, they are bent.
Reply 7 of 13, by Mike 01Hawk
So'd you put a wide blade putty knife between the CPU and HS and twist yet?
Reply 8 of 13, by Malik
How long do you have to put it in the freezer?
Reply 9 of 13, by Kreshna Aryaguna Nurzaman
I thought you're not supposed to twist the knife. It'll damage the chip, no?
Kreshna Aryaguna Nurzaman.
Reply 10 of 13, by Tetrium
I got a related question. I have a couple cpu's I removed the HSF from, but theres a large thick piece of glue left on them which is impossible to remove with alcohol. Anyone have any idea on how I can get the thick layer of (white/yellowish) glue from the cpu without damaging it too much?
My retro rigs (old topic)
Report spammers here!
Reply 11 of 13, by Mike 01Hawk
Kreshna, I wouldn't think so if the blade is the width of the chip. <shrug>
Tetrium, straight edge razor blade.
Reply 12 of 13, by Kreshna Aryaguna Nurzaman
If I recall correctly, someone on 3dfxZone forum said it's better to use a pencil (or other cylindrical object) as the knife's leverage instead of twisting the knife. If you're using leverage, you won't put pressure on the chip (as opposed to twisting).
Reply 13 of 13, by Tetrium
Whenever I (try to) remove a heatsink from a PCB using something to use as a lever, I'll put a small plastic card (like an old telephone card or old credit card or so) and hold it on the PCB to prevent damage to the PCB.
The very 1st time I twisted off a heatsink from an old graphics card, I accidentally broke off one of those tiny resistors 😦
Still seemed to work though but I'd rather not take any chances of damaging something
