Thanks a lot for your elaborate reply. I deal with it in parts. I am talking only ATX mobos here. As far as I can see it, the choice comes down to Asus P3B-F or AOPEN AX6BC. In either case: 1 AGP, 5 PCI, 2 ISA, one of them shared.
elianda wrote:So you say graphics card, V2 SLI, V1, PCI Sound, PCI Network <- so all 6 slots are used. Considering you want to use another ISA […]
So you say graphics card, V2 SLI, V1, PCI Sound, PCI Network <- so all 6 slots are used. Considering you want to use another ISA soundcard you need 2 ISA slots.
So when optimizing this there are several possibilities:
You drop a PCI card for USB 2,
best candidates are the V1, if your games will run on V2 too
maybe one V2 but I guess you want the SLI if using V2 at all
or the PCI soundcard if the ISA soundcard is sufficient.
The machine will have at most two soundcards. One ISA, one either. My demands are definetly less then 100% perfection in this department. I was used to SBpro in the early nineties, later SB32AWE and AWE64 Gold.
My current strategy would be to run a V1 and a V2 parallel at first. Should all my games run on the V2, I would drop the V1. Then I would see, if SLI works too. Since the main card will be a V5 5500 AGP, not too many games should require V1/2 (I hope).
The PCI Slot next to the V5 shares an IRQ with the AGP. It would be desireable to use it with a IRQ-less Voodoo1/2. This would require a mod for cooling the V5 like venting the gaps with a huge fan.
Another option is to look for a mainboard with onboard LAN f.e.
the problem with this that usually on the older boards this solution is implemented instead of a PCI slot/device. So you usually don't win a slot with this.
I wouldn't even know of one, that offered this.
As for the decision whether or not to use a network or fast USB 2 card I would always use the network solution. I guess your Win98 system already has at least USB 1.1. So for what exactly is USB 2 required?
Do you transfer such amounts of data to or from your retro PC which can't be transferred by LAN or via USB 1.1 ?
USB2.0 is wanted for backup and file transfer from HDD, card or stick. If it would work, it could be used with a usb-network adapter too, perhaps saving the network slot. The manual of the card holds no information regarding PCI 2.x. Should it not work, so be it.
swaaye wrote:You can't build a machine that will work with everything. That project will end up over budget and with no solution. 😁
No kidding, swaaye? 😉
swaaye wrote:I think the best you can do is build a box that will run most games from the 486 era up to DirectX 8 stuff. Older games will usually need quirky speed tweaks.
That is exactly what I am after. And I limit it to stuff that will not work fair under WinXP. So I don't think I have too much trouble.
There are a few 440BX mobos with 3 ISA.
I am not as crazed about audio (yet) as some others are around here. Two audio cards should be all I need. Perhaps even one will do.
Just yesterday I checked Warlords2 with a lot of my cards hooked up to the main stereo. I found that despite all the bitching, my AWE32 non PNP with yamaha DB sounded best to me. So I might just take that as first choice. I would only want to add a SBpro compatible card with an OPL3 and a DB connector, so I could shift the DB or the FM synthesis there. I also have an CMI8330A on the way, which gerwin did consider a good alternative.
However, I consider it quite a possible option to just use the AWE32 with DB alone, accepting SBpro in mono. I have tried enough audio choices, which were all budget picks. All I really need in the Dos department is clear SBPro OPL3 plus DB, so I may just add a card that offers both. (Would YAMAHA YMF719E-S qualify?)
Edit: CMI8330A just arrived. I shall finish up my work and resume testing asap...
