First post, by Serious Callers Only
Question in title. Thanks.
Not sure if that works for imgmount. Any way just hex-edit the image if you really need that changed.
Oops 😀
1+1=10
It doesn't.
But also doesn't matter. The problem was the buggy daggerfall installer not recognizing free space (solution, run with parameter: install.exe /u).
wrote:(solution, run with parameter: install.exe /u)
Or just use the -freesize switch when you mount the C drive.
