First post, by digitaldoofus
I'm often puzzled by websites that say the CSP/ASP chip is "built-in" on the CT1740 (see link below for example)...and yet, there seem to be *far* fewer out there with the ASP socket filled, than not.
Anyone got an explanation for this?
http://www.cage.curtin.edu.au/mechanical/info … ons/sndcard.htm
Once you go retro, you'll never go back...
Reply 1 of 6, by Salient
I know there are 1740's with and without CSP/ASP.
I have an SB16 ASP with the ASP chip soldered on the board rather than socketed. I know that my first SB16 ASP ever (back in 1993/1994?) was like that too.
I also remember being not happy AT ALL with it after a week or so and really regret selling my SB Pro 2 and got that thing. 😀
Reply 2 of 6, by digitaldoofus
Why did you like the SB Pro2 so much better than your ASP SB16?
Reply 3 of 6, by digitaldoofus
By the way, can anyone point me to a link for downloading ALL the original SB16 install disks for the model CT1740? (yes, including the nonessential applications). How many disks were there...3? 4?
Reply 4 of 6, by retro games 100
Creative released quite a lot of SB16 cards. I think the CT1740 was one of the first. The general sound quality isn't very good - it's kind of "muddy/unclear". The later ones were better, eg CT22xx, and also the Vibra chipset ones were better too, eg CT28xx. I think the only good thing about the CT1740 is its wavetable header probably isn't faulty with the MIDI hanging note problem, because I think that model had the "good" DSP version.
Reply 5 of 6, by digitaldoofus
Yes, the only reason I'm installing the CT1740 is because I need Wavetable daughtercard capability. The PC I'm putting it in, only has one open ISA slot that I can use for my sound needs, so I'm planning to use a CT1740 with Roland SCD-15 daughtercard (I'm also hoping to use the SCD-15's MT32 emulation for titles that support MT32).
Reply 6 of 6, by Salient
In that time, games that supported the sb pro in stereo weren't stereo on the SB 16. The only that was as far as I remember was wolfenstein 3D, but the sound was hissing SO much and clipping SO much that it really spoiled the fun playing it on the SB16.
A lot of games had the problem with hiss and clip.
I paid about 600 guilders (!) for it back then (that was about 300 dollars) and given the above facts you can imagine I really felt screwed.
