First post, by Unregistered
When I try to play, for example, Settlers 2, VDMSound always whines about my com ports. I have only com1 enabled, because it's the only port I need, for my calculator. When I have other ports disabled, I get a message like this: http://www.kotiposti.net/ihmemies/tavara/errmsg.png
It's very annoying to always click ignore, I have to do it with TTD three times! Is there any (commandline) option or something to disable that nag screen? I'm not interested if game x doesn't get all the 4 com ports it "needs".
Another issue is my joystick, Logitech Wingman Digital 3D (no force) with Archimedean Dynasty. I have Windows XP, and I've tried both usb and gameport. VDMSound supports joystick emulation, but the config window in Archimedean Dynasty just says "no joystick detected", when it should work (at least it works in Windows).
