First post, by retro games 100
- l33t
I am testing a PCI S3 STB Trio64V+ VGA. It has 2MB of DRAM. It has an id sticker on the back that reads "VIDPCI009ABWW". I looked this up on the net, and it looks like it's from a Gateway PC. The following downloads have been tested -
1) Link to the Gateway webpage, includes w95/8 driver: vid018d1.exe, and windows 3.11 and DOS driver: stb211t.exe.
2) Link to the "generic" S3 driver package, for Windows 95 and 98. (w9524107.zip)
3) Link to the "generic" S3 driver package, for Windows 3.11. (w3117004.zip)
Notes -
1) vid018d1.exe tested on Windows 95. stb211t.exe tested on WFWG 3.11. The Gateway webpage link above is very good.
2) Tested on Windows 95. Btw, these driver filename links can be cross checked with the file names found on S3graphics.com.
3) Unfortunately, I have not tested this driver yet because I cannot install it. I have described this problem here. Begin edit: I have been able to test this now. I changed the video card inside Windows, instead of using the DOS prompt to run Windows\setup.exe. End edit.
