First post, by asteff54
Running DOSBox .74 on Windows 7 HP Laptop
Trying to install and run NBA Live 95
I have the original disk in my e: drive
I can only get so far until I receive an error sating that my hard disk is full and I need to delete some file to install the game
Here is what I have so far:
I open DOSBox
Z:\>mount c "c:\users\your name\oldgames"
Directory c:\users\your name\oldgames doesn't exist.
Z:\>c:
Drive C does not exist!
You must mount it first. Type intro or intro mount for more information
Z:\>mount d e:\ -t cdrom
MSCDEX installed
Drive D is mounted as CDRom e:\
Z:\>d:
d:\>install
DOS/4GW Professional Protected Mode Run-time Version 1.97
Copyright (c) Rational Systems, Inc. 1990-1994
Your hard disk is full.
You need to delete some files before you can install the game.
D:\NBA95>
What do I do now????
Reply 4 of 5, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Your windows username is really "your name"? And if you didn't type that in you entered this in the autoexec section of the config file. If you didn't do this as well then you are not telling us the whole story, especially where you got that config file from and why you are loading that.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
