First post, by earlyraven
I'm experiencing a problem in which, after starting up a game in dosbox, the mouse is stuck along the edge of the (dosbox) screen (That is, the top and the sides). What can I do to fix this?
I tested this with another game, just to rule out it being a game specific problem. The problem persists for both M.A.X. (Mechanized Assault and Exploration) and Betrayal at Krondor.
Details:
The problem occurs when running the game(s) through dosbox inside VMWare. (So, perhaps this is a VMWare issue, I don't know). In all cases I used the latest version of dosbox: .74. Here are some scenarios:
** Windows 7 (64 bit) host >> VMWare running Windows 98 >> Run game w/ dosbox >> Mouse locked up on edges
** Windows 7 (64 bit) host >> VMWare running Windows 2000 Pro >> Run game w/ dosbox >> Fail... won't start... complains about needing 256 colors. (VMWare tools failed to install, so this may be why).
** Windows 7 (64 bit) host >> VMWare running Linux Mint 13 (KDE) >> Run game w/ dosbox >> Mouse locked up on edges
** Windwos 7 (64 bit) host >> VMWare running Windows XP SP3 >> Run game w/ dosbox >> WORKS FINE!
** Windwos 7 (64 bit) host >> Run game w/ dosbox >> WORKS FINE!
** Windows XP Pro SP3 host >> Run game w/ dosbox >> WORKS FINE!
So... any ideas about why mouse is stuck in Win98 and Linux Mint 13?
Do you need more info? Ask and I'll see if I can provide.
