First post, by DOSCake
Howdy all,
I'm setting up dosbox to run an older dos database app in Windows 7 64nit. The app which looks for c:\snap is loaded on c:\dosboxfol\snap. I've mounted c: in dosbox to c:\dosboxfol\ so that snap resides on c:\snap in dosbox. I've enabled full access to all users in both folders via security settings in win 7.
The dos app when loaded from dosbox throws up a notification saying that is trying to open the first file related to the database that is default. It either can't find it or its locked, from what I can see it's not locked.
I've tried running dosbox as admin is well with no luck. Any help would be great.
Thanks,
~DC
