First post, by marquisor
- Newbie
hello there SCSI freaks!
got an adaptec 2940UW and adaptec 29160 controller here. LVD and SE cables. with termination.
the rig is a p233mmx, 128mb ram.
with the SCSI HDD Fujitsu MAP3367NP FW 0107 it syncs at 40MB/s with 2940UW and 160MB/s with 29160 controller.
with both controllers, any cable configuration, any jumper configuration, i only get 10MB/s max. throughput. with several benchmarks, dos (speedsys, hddspeed) and windows (crystal disk mark).
any suggestions?
i'm searching the web for a firmware upgrade but didn't find anything related... toshiba now has support for fujitsu brand, but also nothing there.
PS: other drives working fine with their correct transfer rates. also tested everything in a second rig P133, 32MB. same problem.
