First post, by Lassar
I programming a dos program, and need to know if DosBox Turbo supports MMX OR SSE?
If it doesn't then, I will avoid using those assembly instructions.
Conquer the FCC GROL, & Amatuer Radio test
Reply 1 of 9, by Xelasarg
It should support everything that DOSBox 0.74 does, except the features removed due to limitations of the Android OS (like General MIDI support).
Best to ask the DTurbo dev, though, as this port isn't officially supported here.
"What's a paladin?!"
Reply 2 of 9, by kolano
No offical version of DOSBox yet supports MMX or SSE instructions.
Future SSE is unlikely as no DOS game I'm aware of uses such (it came out too long after the demise of DOS). MMX is also generally unsupported, though the Yhkwong version of DOSBox does include a pentium_mmx CPU type. It theoretically supports the full MMX instruction set, but may also be buggy.
Old, further discussion of MMX support at...
Pentium MMX emulation - possible?
MMX
Reply 3 of 9, by yahma
Seeing as DosBox Turbo is just an Android Wrapper around DosBox proper, then no. It does not support MMX.
Reply 4 of 9, by leileilol
And no, the MMX support in that MMX patch isn't perfect either.
Reply 5 of 9, by robertmo
i thought the mmx patch only adds mmx detection support
Reply 6 of 9, by kolano
I'm not sure. The MMX patch from the other thread I posted states...
kekko wrote:
I made this patch few days ago, it's the complete mmx instruction set for the dosbox interpreter.
...I'm not fully clear it's the patch in Yhkwong's build though.
Reply 7 of 9, by yahma
There are only a handful of games that use MMX. So I'm just wondering (out loud) what the purpose of MMX in DosBox would be other than to run those few titles? Emulating MMX would not make existing games any faster.
Reply 8 of 9, by robertmo
Re: MMX
Reply 9 of 9, by kolano
I think there are few games that offer additional functionality/graphics features on MMX CPUs.
-Extreme Assault (For bilinear additive explosion sprite filtering)
And various titles won't run without it, though mostly on Windows.
Windows Titles:
-Virtual On
-Rebel Moon
-Serious Sam
DOS Demoscene productions:
Dead Flowers by Haujobb
I'm guessing this list is not comprehensive.
