First post, by zkl
On gog.com old dos games come packaged with dosbox. I have a cousin that is not that computer literate, but I want to help him play some old freeware apogee games. Is there a way to package those old games with dosbox so that he can play them easily, without having to use the command line?
Thanks!
Reply 1 of 7, by duralisis
Sure can, just do it the same way Gog does by using command line options and a batch file/shortcut to start the game fullscreen with whatever options you've already set. For example, put your game and a dosbox distribution into the same folder, then set a shortcut to start like this:
dosbox.exe -conf game.conf -noconsole -c exit
You can use the default dosbox.conf or make your own (game.conf) specific version. Consult the wiki or see sticky posts for manual config editing. This way you can setup a "machine" config that matches the period of the game and plays it exactly the way it was intended. Then just zip it all up and share as needed.
Reply 2 of 7, by Hater Depot
Set up shortcuts that you can place in his Start menu or desktop. For example this is my shortcut for Space Quest 5:
"C:\Program Files\DOSBox\DOSBox.exe" -conf "C:\Games\DOS\Dosbox configs\sq5.conf" -noconsole -exit
Korea Beat -- my cool translation blog.
Reply 3 of 7, by rcblanke
Maybe try my gamepackarchives.
Reply 4 of 7, by Jorpho
Y'know, only a couple of them have been officially released as freeware; most of the other Apogee/3D Realms games are still for sale from GOG.com, or from Apogee directly.
Reply 5 of 7, by RacoonRider
Is it fair that GOG is making money on a freeware product?
Reply 6 of 7, by Jorpho
What gives you that idea?! If I am not mistaken, there is nothing on GOG.com with a price attached that has also been officially released as freeware. (Star Control 2 doesn't really count.)
If you're referring to DOSBox itself, well, that's been discussed many times before. Besides, DOSBox has been included in numerous commercial products at this point (such as the Sierra rereleases or the Commander Keen collection on Steam).
Reply 7 of 7, by zkl
Thanks for the tips.
Also, I did not mean to indicate that GOG.com is selling those old apogee games, I just meant that gog.com packages dos box with the old non-freeware dos titles, and I was wondering how they did that so that I could do it for my cousin.
