486 DX4 vs Cyrix 586 vs AMD 5x86
First post, by theelf
Hi, first srry my english
a small question, sadly I dont have a Cyrix 5x86 to test, but I read that this CPU have a much better FPU than a normal 486, is true? how much better?
Im building a nice 😀 486 PC, now have a AMD 486DX4 100, with 16mb ram (2x16mb is on the way, i bought on ebay two days ago)
For normal DOS games is more than perfect, and for Voodoo 1 DOS games too
But for "new" Windows games, i get not too great results:
Quake 2 + Voodoo 1 = great, little slow on some places, but playable
Quake 3 + Voodoo 1 + tweaks
1 bot = 2-6fps
0 bot, just look around = 3-9fps
Daytona USA = playable, little slow, but OK
Of course, i dont expect the Cyrix 5x86 will make Quake 3 run great, but do you think will help a little? or better not expect nothing?
When i say "little" is like 30 or 40% more than the DX4
Sorry to ask, but Cyrix 5x86 are a little expensive...
Thanks!
Reply 1 of 54, by mr_bigmouth_502
Honestly, I wouldn't use a 486 box to run any of the Quake games, except maybe if I were playing around with GLQuake or VQuake on a PCI-equipped system. For Quake 1 on the software renderer, you really need at least a Pentium 1, though a Pentium II is even better. As for Quake II, it runs great on a Pentium II with a decent OpenGL-supporting GPU, and Quake III is fairly playable as well. To really make the first three Quakes run well though, go with a Pentium III box.
As for other Voodoo 1 DOS games, again, I would go with at least a Pentium 1.
Reply 2 of 54, by theelf
Well, the idea is to make a 486/5x86 socket 3, no pentium or pentium overdrive, and push to limits
If i want to play Quake 3 at brutal FPS, i will do in my Pentium D + 8600GT, with High Quality Textures, no need for a P3 😀
I was reading this great benchmark
The Ultimate 486 Benchmark Comparison
I can see that the FPU in the 5x86 in a stock 100mhz, is at least 30% more strong that the 486 at 100hz
Someone tested in Quake 2 or 3?
Thanks for reply
Reply 3 of 54, by leileilol
or d_mipcap 3 😀
r_dynamic 0 helps as well, at least in GLQuake. I did implement that in software too. 486s just get real upset with the lightmap surfaceblocks and the dynamic light marking routines
long live PCem
Debian's fucked
Reply 4 of 54, by RacoonRider
Why would you do that?..
Reply 5 of 54, by theelf
People, a question, find a Cyrix 5x86 100mhz is impossible, at least not possible without spend a lot of money
I can get a AMD 5x86 133 P75 for 5 euros, like 6 USD
The difference in "real world" (Quake, Quake 2, etc), between a AMD 5x86 vs a Cyrix 5x86 is soo big?
The AMD 5x86 for this price looks very good...
Thanks!!
or d_mipcap 3 😀
Thanks, nice tweaks!
for Quake 1 and 2, small tweaks like this, make this two games very playable at normal quality
For Quake 3, is necessary heavy tweaks, and lowering all to minimum quality, to get some small playability
..mmm... to check how much a 486 can do, to check if Quake 3 is Pentium only , etc... but...
the best is to read when Quake 3 start in the log "PROCESSOR: Pre-Pentium" 😊
Reply 6 of 54, by sunaiac
the AMD P75 is nothing more than a 486DX5 133, it does not get any FPU improvements.
R9 3900X/X470 Taichi/32GB 3600CL15/5700XT AE/Marantz PM7005
i7 980X/R9 290X/X-Fi titanium | FX-57/X1950XTX/Audigy 2ZS
Athlon 1000T Slot A/GeForce 3/AWE64G | K5 PR 200/ET6000/AWE32
Ppro 200 1M/Voodoo 3 2000/AWE 32 | iDX4 100/S3 864 VLB/SB16
Reply 8 of 54, by mr_bigmouth_502
or d_mipcap 3 😀
That makes me wonder, what would Quake have been like if iD weren't so hell-bent on optimizing it for the Pentium?
Reply 9 of 54, by d1stortion
Probably still a first-person shooter game with lots of brown blocks.
Reply 10 of 54, by sliderider
Keep checking the scrap computer parts listings being sold for gold recovery. I found a Cx5x86-120 in one of those once and didn't pay anywhere close to the going rate for the parts that were in the lot. I could sell off everything else I got in the lot and keep the Cyrix chip for myself and still be in profit. You take a chance with the scrap lots that the parts you get may not work, but I haven't had very much not work yet.
Reply 11 of 54, by mr_bigmouth_502
I agree, the color scheme on Quake (and to a certain extent Quake II) was quite bland. They really could've done a lot more with 256 colors. 🤣
Reply 12 of 54, by silikone
I thought a 486 wouldn't be able to run Quake at all, due to the lack of certain math functions.
Do not refrain from refusing to stop hindering yourself from the opposite of watching nothing other than that which is by no means porn.
Reply 13 of 54, by leileilol
Only the 486SX (and 386SX too. Yes a 386dx can run Quake)
long live PCem
Debian's fucked
Reply 14 of 54, by d1stortion
Quake II was pretty awesome with its obnoxious bright colored lighting. That really was a good recipe against blandness in FPS games of the late 90s. Of course Quake III had to be a brown mess again.
Reply 15 of 54, by leileilol
Q3A isn't a brown mess - though it does have a lot of red and gray. Team Arena added a crapload of blue if you're wanting the flavor of "millenium cheese". 😀
Q2's colored lighting suffered from clamping out its volume though - it was very dark compared to the software renderer.
I was working on a new ref_soft.dll that would bring its colored lighting into software mode with overbrights. The only id Tech 2 game that even bothered to enhance the software renderer is SiN.
long live PCem
Debian's fucked
Reply 16 of 54, by theelf
Hi,
after some researching, i believe the best option to upgrade my AMD 486 DX4 100 is the AMD 5x86 133mhz
From feipoa benchmarks, i can see the AMD 5x86 stock, give 82.3 ALU / 54.6 FPU, vs the 69.6 ALU / 63.6 FPU
While the Cyrix will give me 10% more FPU speed, it lost in the ALU
Sadly, in my motherboard when i use a bus of 40mhz, the cache get crazy.... 🙁 only works ok in 25/33mhz bus
I tried to overclock the AMD 486DX4 100, using 3x40mhz, and i get 120mhz, but i need to disable L2
100mhz with L1 is more fast than 120mhz without L2
Hope i can find a solution...
My motheroard is a AB-PB4
http://www.amoretro.de/2012/01/abit-pb4-rev-1 … otherboard.html
Quake and Quake 2 will for sure like a lot this 10% best FPU, but emulators, like Callus or Genecyst for sure will be more happy with the better ALU of the AMD... no?
By the way, talking about Quake, in the AMD DX4 i get solid FPS in Quake 1 iw/ Voodoo 1 and very good fps in Quake 2, only drops in big outside areas or with lot enemies , but still playable
Quake 3 is slow to be fully playable, but, the idea was never play Q3 in the 486, but, just be happy to know my 486 can run Q3 😀
Yesterday i was "optimizing" Callus, and after install SDD vesa, use linear, reduce sound quality to 11025, give me 19-29 fps (no less, even in heavy games), then with a frame-skip of 2, i can get full speed
Very playable, is beautiful to se Final Fight in my 486
If benchmarks are correct the 5x86 133 will give me a 33% more raw speed.. that means that even in worst situation i can get 25fps
What do you think guys about this? someone have a AMD 5x86 133mhz and can test callus on it? 😀
Sorry, here in Spain, old computers parts are very expensive
Bye!
Reply 17 of 54, by leileilol
What about Vampire Savior on the 486? Is that possible? 😀
it's sort of possible on Pentium MMX and the qsound is faster to process than fm synthesis because that's nothing more than raw 16-bit PCM on 16 channels...
long live PCem
Debian's fucked
Reply 18 of 54, by theelf
uff... Vampire Savior is CPS2...
In callus Street Fighter Alpha 1 CPS CHANGER works really good, like other CPS titles, 19-25fps
But CPS2 even in my 233mhz @260 using DOS Raine (fastest CPS2 emulator) skip some frames jeje, but really need 64mb ram
Anyway.. will test..jeje 😀 later i will came back with results
Oh, by the way, the NeoGeo CD emulator, without FX sound, but with audio CD, give me constant 20-27fps!! sadly the emulator dont have any frameskip option 🙁
If the emulator have frameskip, neogeo in the 486 !!! sad
Reply 19 of 54, by leileilol
The emulator I used on the Pentium was WinKawaks. Gets real fast in mono sound with the music turned off (not sound! Kawaks can disable music if it has the proper jukebox dat files), playable enough to complete
I haven't really ran vsav on my 486 because I lack the ram 😀
long live PCem
Debian's fucked
