First post, by Standard Def Steve
I'm trying to connect my 9800 Pro to a 1920x1200 LCD using DVI, but it outputs garbage at that resolution (or any other 16:10 option). Anyone know of a fix for this? I've tried different drivers and have tried to "reduce DVI frequency for high-res displays," all to no avail. The analog output will do 1920x1200, but the picture is muddy.
It's a little frustrating because my Radeon 7000 PCI can drive this monitor at its native resolution over DVI.
"A little sign-in here, a touch of WiFi there..."
