First post, by bestemor
- Oldbie
Trying to find DVI-I(male-male) of good quality, mostly for use with monitors that doesn't have VGA, but signal comes from analog VGA source (via passive VGA-DVI adapter).
In lengths of 2-3 meters or close.
DVI-D is no good, no analog signal gets thru.
http://en.wikipedia.org/wiki/Digital_Visual_Interface
Yes there are cables to be found, but I'd prefer some better quality ones, if they exist.
Not having the ferrite 'tubes' or 'cans' (in lack of better words) would be a sign of that I think, as well as a much thicker cable - but not necessarily.
Any suggestion of existing names/makers/models etc would be appreciated.
And links (ebay, European webshops) even better! 😁
Worst case, going HDMI instead, there are vga2hdmi powered converters, but expensive...
