386 locks up in SQ4CD
First post, by Mau1wurf1977
Hi!
My 386 is having issues with SQ4CD (using ADL.DRV and AUDBLAST.DRV).
PC is a 386DX 40 system. 8x1MB RAM. 256KB Cache. MS-DOS 6.22 with a single 500MB FAT partition. EMS memory, 600+K conventional RAM.
The game is the SQ4CD version from GOG.com (files copied onto a CF card).
The game freezes during the introduction at various points, but speech has been going for quite some time. No digital looping sound or anything like that.
Usually around the scene at the bar. The same files work flawless on my Super Socket 7 time machine.
But one time I got a crash back to DOS with an error message:
zero hunk allocation request. Script #: 0, IP: d41
Any pointers as to what this could be causing this?
PS: Will try a different sound card next.
Update 1: Same issue with a SB16.
My YouTube channel
Reply 1 of 6, by collector
I'll assume that you have successfully had blaster sound working on this PC before and can eliminate certain obvious PC issues. I have found that GOG sometimes has some mismatched audio drivers that can cause memory errors. I have the GOG version, but have not taken a look at it. The AUDBLAST.DRV driver from the originals CD has an MD5 of 1AEA52D70881ADD2CF1FD375AF2D65CC. The only other thing that I can think of off hand is a mismatched blaster IRQ, but would think that if this were the case that it would result in a lockup instead of a hunk error. BTW, the interpreter version that the CD version uses does have an IRQ flag for the RESOURCE.CFG -- "audioirq=" to set the game to use 7 or 5.
Reply 2 of 6, by Mau1wurf1977
I'm slowly getting there. Might be a RAM issue.
I transplanted all the cards + storage onto another motherboard and it worked fine there.
I removed 4 sticks and it also worked fine. Then put the 4 sticks back and it froze again.
Will run memtest overnight although I'm sure I did this already 🙁
It's not a software issue as I used this installation for years and it runs fine on the other computers.
I was hoping the error message provides a clue.
My YouTube channel
Reply 3 of 6, by NewRisingSun
The error message indeed hints at memory corruption. It is not necessarily that the memory chips themselves are faulty, it also might be a resident program or device driver corrupting memory. Try running the game with and without using extra memory (as the INSTALL program calls it) and see if that makes a difference.
Reply 4 of 6, by Mau1wurf1977
I pulled out all 8 sticks and put them in another 386 motherboard and the issue moved to the other board 😀
So at least I'm getting somewhere. Memtest didn't find any issues overnight though...
I will test 2 sticks at a time in a 386SX board to see if I can identify the faulty chip at all.
Is there a specific version of memtest that is "better" for 386/486 computers?
And another question. When using "extra memory" the RESOURCE.CFG uses ARM.DRV although there is no such file in the folder.
And in the Steam version of the game is mode=real. What does this refer to?
My YouTube channel
Reply 5 of 6, by NewRisingSun
What are "sticks"? RAM? Why is that called "sticks"?
Doesn't matter. When you choose mouse support, it also mentions STDMOUSE.DRV even though there is no such file either.
That's for the INSTALL program's boot disk maker. It's not used by the game itself.
Reply 6 of 6, by Mau1wurf1977
Never heard the expression RAM stick?
It's another way for saying SIMM module 😀
None of the SIMM modules threw an error on the 386SX 😵
I'll bag them with a note for future testing...
My YouTube channel
