First post, by FeedingDragon
- Oldbie
I followed the guide Windows 3.1x DOSBox Guide to set up Windows 3.1 mainly because I have a stack of old CD games that only work in 3.1 (not 95, not XP, etc...) I want to try out. I started with the latest SVN build, and it worked great for getting into windows and just messing around a bit. However, every game I tried would crash after a couple of minutes. The Daum build seems to play the games just great, but I have to use the et4000 machine, because despite changing everything I could, the S3 machine results in a big black box instead of the mouse pointer in Windows. I've tried the drivers on Vogons Drivers page, I've tried drivers from Google searches, and I've tried the legacy driver from the S3 web site. I would much rather use the S3 machine as it allows me to set Windows to 1024x768x32 which closely matches my native LCD display (1366x768,) setting it to black bar the sides, that means there is no resizing going on. The T4000 limits me to 16bit up to 800x600 and 8bit above that.
The guide specifically mentions the S3 as working fine, so I'm assuming that the mouse is a pointer and not a big black box. Attached is the config file and an image of the problem.
My current system:
Windows XP SP3 32bit
Intel 2.4G Duo-Core
4G Ram
AMD Radeon HD6670 2G
Soundblaster X-Fi
Feeding Dragon
