First post, by paraemuladores
Hi there. I'm trying to run Creature Shock on DOSBox 0.74. The problem is, it doesn't have sound. I posted in a wrong forum, here's my old post:
Creature Shock doesn't have sound
Postby paraemuladores » 2014-3-21 @ 01:11
Hi there. I'm trying to rum Creature Shock on DOSBox. I tried modifying every setting in the configuration file that I could think of, like changing the soundboard, adjusting the cycles to 40000, using gravis ultrasound instead of soundblaster, adjusting the irq, dma and hdma, etc. The problem is not the sound itself, it's the fact that the game doesn't detect any sound board in DOSBox. When I open the configuration file, the soundboard and the midi device says "UNDEFINED". And, when I install the game, both from windows and from inside DOSBox itself, it algo says "Soundboard: None" and "Musicboard: None." I do believe that if I can specify in the configuration file the type of soundboard, I could make the sound work, but I don't know how to do that. Any ideas? I'm using DOSBox 0.74, I have a core 2 Quad Q6600, 4 GB of RAM, and a N560GTX video card.
so I'm posting here (thanks, truth5678). Here's what truth5678 told me:
-First, try another game to test that sound is working via dosbox
Done that. I've run Crazy Drake with no sound problems whatsoever.
-Second, slow down the cycles a lot to verify that sound board detection is not hampered by high cycle count (set cycles=15000)
Done that, too. Tried also 40000 (like another post says) and auto. No effect.
-Make sure it isn't abandonware software, too, because that may cause an issue.
I don't know if it is abandoned, but Creature Shock is in the game compatibility list of DOSBox games, as %100 supported, from version 0.72.
-Here are the suggested sound settings: Sound - SoundBlaster 16 (A220,I5,D1)
Done that, too. It still doesn't detect any card at all.
-Music - GeneralMIDI (A330)
The configuration file doesn't explain in detail how to configure midi sound, so I'd ask if anyone can show how it's done. I don't know how to configure to General Midi, the explanation of the configuration file doesn't explain it, nor does the manual.
-This means you would also set IRQ=5 in the dosbox.conf file. See wiki for dosbox.conf for details on these settings.
Could anyone direct me to this wiki, please? And I don't understand wich IRQ is meant in that last sentence.
