First post, by ncmark
Could someone shed some light on this? I have a seagate goflex drive that is turning itself on and off under XP - it won't even stay on long enough to recognize the drive.
My first guess was a power problem - maybe it trying to draw more than the port can supply.
My second guess is something windows is doing - it seems to run until Windows finishes loading, and then the cycling starts. Yet it worked fine for a long time, and nothing else has changed.
There is nothing wrong with the drive, and other devices work fine in that port.
Very puzzling!
Reply 2 of 2, by ncmark
Thanks for the reply!
I think I found the problem. I noticed the BIOS was giving me an error message in the power section... the +5 volt supply was down to 4.46 volts. I put in a different supply and it seems to have fixed the problem.
This may also explain some of the other problems I was having with the system - I will have to wait and see on that
