DOSBox SVN Daum
First post, by Bitfresser
Hello,
I have troubles in installing DOSBox SVN Daum on my Debian Wheezy system (64bit).
I'm absolutely new in Linux. I require DOSBox SVN Daum to access my parallel port for driving a DOS program with a dongle.
I have downloaded the latest version of the program from http://ykhwong.x-y.net.
When I execute the program "dosbox", I get the message that I have no rights to execute.
When I provide the respective rights to the program "dosbox" and I call it, then I get the message:
- file or directory not found
Can anyone help me?
Reply 1 of 5, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Generally you will have to contact Ykhwong directly for support with his SVN build. As with his OS X build I guess he made too many assumptions of where stuff is supposed to be without giving instructions...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 5, by Bitfresser
Thanks for the quick response!
Meanwhile I found out the problem. The current version is a 32bit version, which I can run under 64bit-linux after including 32bit architecture:
# dpkg --add-architecture i386
# apt-get update
# apt-get install ia32-libs
However, running the program requires GLIBC_2.15, GLIBC_2.16 and GLIBC_2.17 that are on the libc6-dev package.
This is experimental:
# apt-get -t experimental install libc6-dev
Is there anybody, who can compile a 64bit version of the DOSBox SVN Daum? I'm unable to solve out all the occuring compilation errors.
Reply 4 of 5, by Bitfresser
Thanks for that advise.
I found out that installing the (unstable) experimental libc6-dev package leads to a lot of errors under Debian.
Under Ubuntu, the GLIBC_2.15, GLIBC_2.16 and GLIBC_2.17 are already available in the stable version. So I recommend to use DOSBox SVN Daum with Ubuntu and not with Debian.
Reply 5 of 5, by Bitfresser
Interessting detail:
According to this HP:
http://ubuntuforums.org/showthread.php?t=1310634
you should use nc.openbsd for redirecting the lpt1 port to a network printer. I tested it and found out, that nc.openbsd blocks the respective printer for everybody in the network, as it steadily keeps the connection by the while-loop.
I recommend to redirect the lpt1 port to a network printer based on the lpr command of cups. It must however be set based on the -l flag, as the prt-files output by dosbox are already formatted.
A good script shoud thus be:
while true do cat /dev/netcatprint | lpr -l done […]
while true
do
done
Do not forget to set a standard printer in advance.
