Upgrade 486sx
First post, by ahendricks18
My upgrade socket says "80487". would this work?http://www.amazon.com/Evergreen-586-Processor … 6/dp/B0009LPJG0
Main: AMD FX 6300 six core 3.5ghz (OC 4ghz)
16gb DDR3, Nvidia Geforce GT740 4gb Gfx card, running Win7 Ultimate x64
Linux: AMD Athlon 64 4000+, 1.5GB DDR, Nvidia Quadro FX1700 running Debian Jessie 8.4.0
Reply 1 of 12, by kixs
What is the model of your motherboad and what CPU is installed? Or post a picture.
80487 is a socket for "math coprocessor" if you use a 486SX processor. With replacing/upgrading CPU you would first remove the old one and place a new one in the same socket and leave the 80487 empty.
Reply 2 of 12, by PeterLI
Reply 3 of 12, by ahendricks18
I found this: http://www.cpu-world.com/CPUs/80487/the Amazon and this link both say 169 pin socket. I'll count the pins when I get home.
Reply 4 of 12, by PeterLI
Check the MOBO first. In case you can install other CPUs it is easier / cheaper to install a 80486DX or Pentium Overdrive.
Reply 5 of 12, by sliderider
Good luck finding a 487. The last two I saw for sale were over a year apart. One was sealed in box for $199 and the other was loose for $99. For those prices you're better off getting a socket 3 motherboard and 486DX chip to put in it.
Reply 6 of 12, by soviet conscript
I beleive this is his motherboard http://stason.org/TULARC/pc/motherboards/P/PA … ml#.VHOTGsmmXN1
its a Packard Bell system. If you want to stay slow at 33mhz just get a 33mhz 486DX as suggested. as for mixing out the CPU, would an AMD 133mhz work in this machine, I assume so. It wouldnt give quite the power of the POD but I think its a cheaper option for good power.
Reply 7 of 12, by Robin4
Why not first trying to make that IDE connector before looking further.
Reply 8 of 12, by ahendricks18
Yeah, thats a good idea.
Reply 9 of 12, by soviet conscript
And if for some odd reason IDE won't work for you there's always SCSI.
Reply 10 of 12, by ahendricks18
Yep. Scsi cards are pretty cheap compared to IDE cards.
Reply 11 of 12, by PeterLI
Reply 12 of 12, by ahendricks18
I'm seriously considering scsi right now.
