Rod Primitive wrote:I have the x64 version of Java installed only, and I've learned from Magic Launcher that I should always increase the value of memory allocated before playing. But do I need to do more than just make sure I have Java 64 installed?
I have my RAM limit set at 8 GB (16 GB available) and even then I still sometimes end up using over half of that. :O
With an 8 GB system I would recommend setting it to 4 GB at least in the launcher's options, maybe even 6 GB. Don't go all the way up to 8 though, otherwise you'll interfere with everything else trying to run.
Rod Primitive wrote:Oh, and I really think you should do a video on FTB and/or Minecraft. Sure, everyone and their mothers might be doing it. But AFAIK no one has made a video about FTB.
Erm... See that "Direwolf20" pack in the launcher? Direwolf20 is a YouTube Let's Player who does nothing BUT modded Minecraft and has been for YEARS, releasing at least one video every single day. :O
...and that's just the tip of the iceberg!
There's tons of FTB and modded Minecraft videos out there. Too much to really get noticed by. If I'm going to do an FTB video at some point it should be for the benefit of the people who already watch my show, which means it needs to be able to demonstrate just how much depth all the mods add, but that's hard to do in a fresh world that hasn't been played for at least a couple or three months, but because I don't play Minecraft every day, it takes me even longer to get anywhere and then I'm routinely resetting my world to try out new stuff with new packs.
So... yeah. One of these days once I can get a particular world far enough along! :B
--- Kris Asick (Gemini)
--- Pixelmusement Website: www.pixelships.com
--- Ancient DOS Games Webshow: www.pixelships.com/adg
