First post, by adam144
Is it possible, and if so how to, export files from the virtual mounted drive onto the local hard disk?
Reply 2 of 3, by adam144
Verified... Thank you Dominus!
So for others who may find the thread later -- although you mount a virtual drive to DOSBox it's still saving and updating to the local directory from which you mounted.
Thanks again
Reply 3 of 3, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Actually you don't mount a virtual drive.
When you do "mount c c:/dosgames", the REAL folder "dosgames" on the REAL drive c:/ gets used in Dosbox as drive c:/. So nothing vietual.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
