First post, by lafguy
lafguy
Offline
I have dosbox 0.74 loaded on 2 other systems. So I copied the exact commands to get everything mounted. No matter what I do it won't mount C on this system.
# Lines in this section will be run at startup.
# You can put your MOUNT lines here
mount C "c:\dos"
mount D "d:\" -t cdrom -ioct1
Mount A "A:\" -t floppy
This command above works like a charm on my other machines why not this one?
All machines have win 7 64 bit on them. This one is higher end but, nothing that should bother dosbox
