First post, by tayyare
I'm in the process of choosing my first ever Tualatin CPU, and I just want to know a few things:
- I just learned that GA-6VTXE can accept Tualatin 1.4 /133/512 CPUs. This is sure?
- The manual says it can accept 370-pin FC-PGA2 CPUs, though it does not mention Tualatins speceifically. This mean I don't need a modified CPU, right?
- SL5XL and SL6BY. Which one of these Tualatins should be preferred, or actually, is there any difference at all?
- Is a stock AMD cooler for Athlon 64 will be ok for this CPU? I'm using it for my current coppermine 1000MHz with pretty good results - massive compared to stock Intel PIII coolers.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 1 of 12, by PhilsComputerLab
I've got this board, yes it will take the Pentium III-S 1.4 GHz Tualatin with 133 MHz FSB 😀
Tualatin chips are a little bit taller, so coolers that worked on standard Coppermine chips, might put too much force on the socket clips. I've snapped them off on one board, that was a shame. So what I now do, is use a fairly tiny Socket 7 cooler, and just put a 120 mm fan on top. This works well on a test bench, but isn't a permanent solution. There are special Tutalatin coolers from Intel and other manufacturers.
You can try to modify the mechanism of how the cooler attaches, basically bend things, so the force isn't as strong.
YouTube, Facebook, Website
Reply 2 of 12, by idspispopd
I use a Celeron 1.0A on that board. (Bought both together new at the time. Running with the boxed cooler.)
The manual indeed doesn't mention Tualatin explicitly, neither and Tualatin CPU in the speed list. But in the "Performance List" benchmark values are given for "Intel New Pentium®III 1200 MHz Processor" / "Intel New Pentium® III Socket 370 Tualatin 1200 MHz". Besides, the whole point of that board is Tualatin support, starting from the 694T chipset (T is for Tualatin).
Reply 3 of 12, by tayyare
Thanks a lot guys. Very clear answers.
I also notice something and wanted to be clear on this also. As far as I understand, there are two versions of Tually CPUs: Modifed and unmodified.
- Are modified ones being modified to work with slot (with an adapter apparently) and normal socket 370 boards? (FC-PGA interface modification)
- I board like mine, which has native Tualatin support, does not need any modification since it is already FC-PGA2 capable, right?
- Is this extra thickness related to all Tualatins, or only the modified ones? From an ebay link:
"...Intel Tualatin Pentium-IIIs 1.4GHz(512K) include On-chip Socket Adapter!!! This CPU works perfectly on most of old P3 CPU Motherboard without other socket-adapter... 370-pin FC-PGA2 (modifie to FC-PGA interface)... This CPU was modified on backside of CPU... Caution : CPU height is ticker(1.1mm=0.0433inch) than original. You may need to adjust a tension of your heat-sink clip."
http://www.ebay.com/itm/281238323137?_trksid= … K%3AMEBIDX%3AIT
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 4 of 12, by Skyscraper
The extra thickness is only for those modified CPUs.
You do not need a modified CPU as your board has genuine Tualatin support (but a modified CPU would work).
Reply 5 of 12, by PhilsComputerLab
Not true. The IHS adds height. So I recommend being careful with mounting CPU coolers. If you need a lot of force, you might snap of the hooks on the CPU socket.
Reply 6 of 12, by Skyscraper
Its true they are a bit thicker compared to CPUs without IHS but the 1.1mm extra thickness mentioned in the Ebay add is only for the modified CPUs 😀
I have never had any problem mounting even the modified CPUs but beeing careful is always a good idea.
Reply 7 of 12, by tayyare
Thanks a lot again, this is really helpful. Now it's time to acquire.
Strangely, there are Tualatin 1.4 CPUs ranging from 6.99 USD + shipment to 30 USD + shipment. I don't know if there is a real difference between different steppings, but will go for the cheapest at first. I'm at the moment trying to convince the seller from US, who is offering them for 6.99, that 45 USD shipment for a tiny CPU is way off. 🤣
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 8 of 12, by kixs
...that 45 USD shipment for a tiny CPU is way off.
Good luck with that 😉
Visit my AmiBay items for sale (updated: 2025-08-01). I also take requests 😉
Reply 9 of 12, by Nahkri
I'm also interested in buying a modded Tualatin since my socket 370 board doesn't support it,if later i'll get a board with Tualatin support will the modded 1 work in it?
Reply 10 of 12, by tayyare
Shipment is 10 USD now!.. 🤣 (no tracking, though)
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 11 of 12, by tayyare
I think this answers it:
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 12 of 12, by Skyscraper
As long as the board also supports Coppermine CPUs this should be true and I never heard of a board with only Tualatin support but I guess there could be some strange OEM board I never heard of 😀.
The mod makes the FC-PGA2 Tualatin a FC-PGA CPU just like the Coppermine, perhaps some voltage clamping is also added but for more technical information its better to ask the Korean dude as he seems happy to answer any questions.
