First post, by Hans Peter
Hi,
I`m trying to start MS Works 2.0 (which runs with minor glitches under dosemu) with dosbox.
When I start the application, dosbox (or Works?) seems to hang immediately after the command with a blinking cursor in the next line. Mouse release (function key) works still, though.
I suppose that it`s a video or a font problem?
Configuration:
Hardware:
Panasonic CF-71, PIII-450, 192 MB RAM, Neomagic AV256 graphic chipset.
OS: Linux 2.4.21, Debian 3.0 woody, KDE 2.2/Oroborus, XFree 4.1.0-16 with "neomagic" driver (all standard Debian packages from stable), kernel from kernel.org, console framebuffer 1024x768 enabled
Dosbox:
0.61-2
all sound disabled but pcspeaker=true
machine switched from auto to vga (with no effect at all)
xms/ems enabled or disabled -> no effect
Works: v2.0 DOS, vga driver, colour mode enabled (should I try monochrome?? or a cga/hercules driver??)
[x] README read, some config switches tried with no effect
[x] FAQ read
[x] Apps Forum searched (but the search term Microsoft Works 2.0 reveals some 50 pages of results, most of them not likely to be applicable)
[x] Google done (same as above)
Any hints?
Thx,
Hans
Reply 1 of 2, by Stiletto
I doubt you'll get too much help, the developers are really more interested in testing games.
If you can recommend a place to buy it or download it, maybe you'll get some help.
do the Fandango!" - Queen
Stiletto
Reply 2 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
Stuff made by MS is usally tricky as MS had inside knowlegde of DOS
There are changes that it will work in future versions. (as we continously find small little bug in the DOS emulation and the cpu emulation.)
Water flows down the stream
