First post, by squareguy
I had some strange issue setting up one of my Audician 32 soundcards last week. My system installed an unknown IRDA device and a virtual com port and printer port. I finally dug through the ini files for the sound card and found it referenced. I have used these before and never seen an issue so it must just be related to a certain hardware combination that causes it to happen. Hoping I will have time to resolve it within the next week or so (when I have some time) by editing ini files and reinstalling. Quirks like this tick me off even though I am sure they don't cause an actual problem.
The latest Yamaha driver from Phil's website
http://www.philscomputerlab.com/uploads/3/7/2 … 621/95v2343.exe
SASOUND.INF has reference: string13="YAMAHA OPL3-SAx ComPort"
SACOM.INF sets up the offending devices.
Any suggestions for the best way to edit to make the virtual devices not install? Just delete SACOM.INF before installing? There are no devices without drivers, these devices are really virtual and I just do not want them. Perhaps they were used in some models for an infrared remote?
EDIT: I would also like to extract all of the cab files to look in there as well. 7zip cannot open them. Any ideas to extract them?
Intel SE440BX-2 Motherboard
Intel Pentium III 450 CPU
Micron 384MB SDRAM (3x128)
Windows 98 SE
Reply 1 of 11, by squareguy
It occurs on a fresh reload only after running setupsa.exe to configure DOS sound card, not from installing drivers.
Any ideas?
Windows 98 SE
Reply 2 of 11, by squareguy
No one ever heard of this?
I am thinking about buying a genuine Yamaha card with YMF719-S instead of the Audician 32 with the YMF718-S.
With a fresh load of Windows 98 you will have your two com ports and one printer port. Install Yamaha drivers and everything is fine, reboot and everything is still fine. Add SETUPSA.EXE /S to your autoexec.bat and when it gets to Windows it starts loading the new devices. You get an IRDA controller, a virtual com port, a virtual ecp port, windows loads IRDA software, your original com and printer port are hosed and the new ports of course do no work (they have the yellow exclamation points. I would love to figure this out and use a Yamaha 71x card in my project, I just love it's OPL3 sound!
EDIT: Would screenshots help?
Windows 98 SE
Reply 3 of 11, by PhilsComputerLab
Just properly reading this.
Why do you load SETUPSA.EXE /S in AUTOEXEC.BAT?
It's a big no no to load DOS drivers in Windows 😀 Windows has it's own drivers. SB Pro emulation will work without loading SETUPSA, inside Windows. And in MS-MODE, SETUPSA.EXE should be setup for you by the YAMAHA installer.
Check out my review again: Yamaha Audician 32 Plus YMF718-S Review
After the driver install, nothing else to do. DOS games should work from within Windows, as well as MS-DOS mode. Only thing to check manually is the resources in Device Manager. Sometimes an Ethernet controller takes IRQ5 and then the Yamaha is configured weirdly. I usually just move the NIC until it uses IRQ10 or 11.
Reply 4 of 11, by squareguy
I will check the IRQ issue
I thought I have always used SETUPSA.EXE /S to initialize the card, I may be wrong. After installing it it puts SETUPSA.EXE /N in dosstart.bat to bring the control panel up when first going to dosmode then it just runs SETUPSE.EXE /S after that without bringing up the control menu to initialize the card.
I could have sworn that after a clean reload I restarted to dosmode, ran the control menu, tested it, got done and typed exit at the DOS prompt to go back into windows and the offending devices started installing. I will try that again tomorrow.
Thanks Phil.
Windows 98 SE
Reply 5 of 11, by PhilsComputerLab
Yup. DOSSTART.BAT is a batch file that gets run whenever you shutdown into MS-DOS mode.
Hmm, ok that would be odd. But yea, don't put anything in Windows 98's AUTOEXEC.BAT. It should be blank AFAIK.
Reply 6 of 11, by squareguy
Phil,
I had some time to test it out. It works great setup as described in windows. I can use the OPL3, Yamaha software synth and wavetable header. There was only a set blaster statement in autoexec.bat.
Booted into msdos mode and the soundcard setupsa menu started. hit enter and continued to dos. Doom worked perfectly with OPL3. Typed exit and went back into Windows and the mysterious devices started appearing 🙁
Since I will not be using real dos on this box I will just comment out setupsa.exe from dosstart.bat just in case I forget and boot into real dos for whatever reason. I am not sure what setupsa.exe is doing but I think it is something outside of opl3sa.inf.
Windows 98 SE
Reply 7 of 11, by PhilsComputerLab
Ok, cool for checking it out again. It's a very odd issue indeed.
Reply 8 of 11, by squareguy
I am going to test this card when it gets here this week and see if it happens with it, hopefully not.
It is a YMF719-S
The attachment $_57 (7).JPG is no longer available
Windows 98 SE
Reply 9 of 11, by alexanrs
I still dream of finding a YMF71x card that supports big MIDI daughterboards without the need to make a cable.
Reply 10 of 11, by squareguy
Hehe. Luckily that doesn't effect me.
I like their sound so much that I am probably about to sell every Sound Blaster I have, which is quite a few.
Windows 98 SE
Reply 11 of 11, by squareguy
The YMF-719 pictured above caused no problems with same driver, the latest one from Yamaha.
Windows 98 SE
