First post, by squareguy
I acquired a SBC (single board computer) with backplane, case and all. It is a 486 with ISA only and onboard graphics. Is this something worth messing with? I could install an ISA video card or is it better to sell this one off?
Intel SE440BX-2 Motherboard
Intel Pentium III 450 CPU
Micron 384MB SDRAM (3x128)
Windows 98 SE
Reply 1 of 11, by alexanrs
If the onboard graphics isn't slow it could probably be a fine DOS gaming machine. Does it have an onboard IDE controller as well? If so, then disk performance might also be OK.
Reply 2 of 11, by squareguy
I believe everything was onboard. I will try to get some pics.
Windows 98 SE
Reply 3 of 11, by squareguy
Pretty sure it was Cirus Logic graphics chip
Windows 98 SE
Reply 4 of 11, by squareguy
Here it is. It has an Intel 486 DX4 100
1.18 MiB
Windows 98 SE
Reply 5 of 11, by alexanrs
ALi chipset, integrated ATA+Floppy controller, 2 72-pin SIMM slots... If that CL chip is on a VLB or PCI bus internally (I doubt that chipset is ISA only), this can be a mighty fine 486 machine. Guess the only way to be sure, though, is testing.
EDIT: check how much cache this boad has, if any.
Reply 6 of 11, by tayyare
Why the Award BIOS sticker is on the Dallas chip?
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 8 of 11, by tayyare
dirkmirk wrote:
Why are these things listed for $400-$500?
These are used mostly for industrial equipment, which mostly having very high prices. These equipment are not something you want or able to upgrade every couple of years on a whim. When a perfectly working 100.000+ USD equipment stops working (which means you can not produce the goods for your customers anymore), the owners are generally more than happy to shell out a few hundred dollars to make it work (and produce goods) again. So, there is the demand, and there is the Ferengi. 🤣
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 9 of 11, by squareguy
Hehe guess I'll sell it!
Windows 98 SE
Reply 10 of 11, by tayyare
Just as I told, here is the Ferengi! 🤣
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 11 of 11, by squareguy
Yeah but it is only a hundred bazillion dollars, good deal for you!
Windows 98 SE
