First post, by rangers14
Hello. I am having issues trying to run this game correctly. I have installed the game to Dosbox 0.74 from the original cd-rom. I can run the game fine at first, but when I try to run the game again using the same teams and same stadium, I get this message: Program Error: Error in view-Out Of Memory loading Image Data(xms mem 9891840) The xms and ems values are set at true, and I have also tried adding and lowering the memory values. Every time I still get the same message though. Any ideas on how to correct this? I also was fortunate enough to find another copy on ebay, but I have had the same results.
The game is for windows 95, but actually is a dos based game. I have windows xp, and have also installed it there too using windows 95 compatibility. When I try to play a game from here I get a Message box that says: Cant open resource\imf.dat :r+t :100'. Someone please help, I am going nuts!!! Thanks in advance.
