First post, by Barbarossa
I've set up DOSBOX and successfully run Master of Orion. However, when I run Colonization the intro works but the program itself (VICEROY) exits with exit value: 19. Does anyone know what this error signifies?
My original game came on diskettes and I've copied all the files to a directory and mounted it such that the directory has the same name as the original installed directory (C:\MPS\COLONIZE). I've tried mounting an A: drive in addition but this makes no difference. Any ideas?
