First post, by Beegle
Just got an original case from IBM, for model 5160 recently. It's empty, and came with no screws.
I thought that normal case screws would work, but it seems they are too small to get any grip. Was the PC screws 'standard' different in the 80s?
Image for reference. Not my case.
80.18 KiB
The more sound cards, the better.
AdLib documentary : Official Thread
Youtube Channel : The Sound Card Database
Reply 2 of 6, by PCBONEZ
Yes. The original size was 8-32.
Modern case screws are 6-32. Same threads/inch but smaller diameter.
Reply 3 of 6, by Beegle
Brickpad wrote:
I would try using 8-32 screws.
Thank you both!
Reply 5 of 6, by Beegle
bjt wrote:
Try to get one with oversized heads
Good point. I'll see what's available the next time I go to the hardware store.
Reply 6 of 6, by PCBONEZ
There is a kind of washer called "Fender Washer".
They are extra big around for the center hole size and usually a little thinner than other options.
(Just in case it helps.)
