First post, by DamienC
I remember playing the MW2 demo on my old Packard Bell P100 in the 90s, and I remember it running fairly well at 640x480. I could be remembering completely wrong.
Now I have a P100 system I built, and I found a copy of the full game. It feels like it's playing between 10-20fps at best, definitely not smooth enough to be enjoyable at all. With all settings turned to low and disabling the enemy display (F4 key twice) I can get up to what feels like 25ish fps, but I'd rather not turn everything off. Game is perfectly playable at 320x200, but I'd rather play at the higher res.
Specs:
Intel Pentium 100-S
Octek Rhino 20+ board (ATX Socket 7, 430TX chipset)
32mb PC66 SDRAM
4gb CF card
Diamond Stealth 3D 2000 Pro PCI (S3 Virge DX 4mb)
DOS 6.22
Is there a way I can speed up the game, or will I need to upgrade something? Tried using the S3 Core VBE 2.0 and S3SPEED utilities; they didn't seem to have much of an impact. Tried overclocking a bit but the P100 doesn't like either voltage increases or multiplier increases.
I was thinking about maybe throwing in a new CPU or video card. I think a 233mhz Pentium MMX or K6 is the fastest this board will take. I don't think a new video card would make much of a difference as my S3 is pretty speedy for most things and I don't think a swap would make much of a difference in software mode. I have zero interest in installing Win95 and getting a 3D accelerator; I want to keep this box strictly DOS.
Reply 1 of 19, by mwdmeyer
Well I used to play Quake 3 on a Pentium 133 @ 14FPS and I thought that was playable back then, so.....
Reply 2 of 19, by vetz
Heh, pretty sure you remember it wrong. Also perceptions of "playable" have changed. Now 60fps is the standard for PC gaming, while 30 was the framelimit and the topgoal back in the days, but in many games the framerate of playable was 15-20.
Reply 3 of 19, by Azarien
But S3 Virge *is* a 3D accelerated card, and from what I read on Wikipedia, there was a special VIRGE version of Mechwarrior 2.
Surely it should work faster than software version.
I have no idea if it works in DOS or requires Win95.
Reply 4 of 19, by DamienC
Probably. I actually DO remember getting through all of X-Wing on a 386SX-20. I went back and installed it on the same system, and holy hell do I find it unplayable now. 😜
There is, but I'd need to install Windows 95 and find a special S3 Virge copy of the game. I actually have an ATI Rage Pro specific version of the game that I found buried in a pile of CDs. I'm not keen on either hunting down an S3 Virge copy of the game or hunting down a Rage Pro either.
I think I'll just try to get a cheap Pentium 233 and see how that goes.
Reply 5 of 19, by gdjacobs
If you want to try the ViRGE accel version, patches are available to convert between versions. Look for MW2 under ViRGE on this list here:
Reply 6 of 19, by leileilol
It won't. ViRGE is notoriously slow, and has the reputation of being a "3d decelerator" for a reason (by 1996 standards even!). It would probably be "faster" if the CPU really sucked for the 640x480 texturing spans, like cacheless Pentiums or late 486s. You're better off keeping the card for 2D (which is okay) and disregarding its "3d" features.
What will help is a Coast module, if you haven't got one in there already. 😀
Reply 7 of 19, by gdjacobs
PowerVR or Glide are the way to go for Mech2.
Reply 8 of 19, by leileilol
No PowerVR for a CPU that slow though. 3dfx is okay (and is fastest in theory for this rig in terms of OEM Mech2 non-Titanium) however its image output is something one would have to get used to/learn to love etc.
Reply 9 of 19, by DamienC
I had a spare CF card lying around, so I installed Windows 95 on it and used the Virge patch on my copy of the game just to see how bad it was. It seemed to only work in 320x200, and the textures looked awful, even worse than software mode. Think I'll pass on that option.
I'd settle for ~30fps in 640x480 software mode in DOS. Still leaning towards picking up a 266mhz Pentium or K6 CPU.
That's cache, right? My board already has 512k cache onboard, and no Coast slot. Just a little confused about that.
Reply 10 of 19, by leileilol
Yep, cache. I mentioned that because I assumed it's a coaster, my P5 100 was such.
Reply 11 of 19, by DracoNihil
I noticed the later engine versions of MW2 had really terrible performance in software mode, but the stock retail 31st Century Combat version could run at 1024x768 on a Pentium 2 at 60FPS... But the graphics are comparable to StarFox on the SNES.
― Κυνικός Δράκων
Reply 12 of 19, by F2bnp
OP what you are trying to achieve is nigh impossible on classic Pentium. I've got a K6-III+ 550 which has difficulty running the game at 640x480 fullspeed. When there's a lot going on, it's not uncommon to see the game run at even sub-20FPS. Your best bet for SVGA Mechwarrior 2 is either DOSBox or a really fast Pentium III (if you want to do 1024x768 that is, which is admittedly really nice).
Reply 13 of 19, by Davis
I remember running very well in 640*480 on my PI-150 with 16 megs of RAM with a S3 Trio64 back in the day. Maybe not 60 fps, but very very fast for that time. That PC was awesome for MW2, Tie Fighter CD and the likes.
Unfortunately, made some bad choices with 3d cards when those came about: first a Virge, than a Riva128. The latter is a nice card, but sucks with a slowish CPU. My friends' 3dfx was not so picky, I recall.
Reply 14 of 19, by F2bnp
Running very well on a Pentium 150? No way. You probably didn't mind constant 15-20 fps 😀. Times definitely do change and the more into it you get, the far pickier you become when it comes to performance and visual quality. I seriously can't stand 20fps or even 30fps anymore and always try my best to get 60fps for a more pleasant experience. As such, most of my systems are complete overkill 🤣 .
Reply 15 of 19, by Iris030380
I played through the DOS version of MW2 with Ghost Bears Legacy installed and it was fairly nice on a P200 vanilla (non-mmx) with 32MB RAM. I can remember it not being smooth, at least compared to the 3D accelerated version I played later with my Mystique. Perhaps 20-30fps in 640x480. It was definitely playable because it's simple game to control with the LRM's and pulse lazers easy to land with low FPS. It's all about positioning right before combat. But certainly a P100 will have little chance at SVGA. I'd suggest a 166Mhz Pentium minimum.
I5-2500K @ 4.0Ghz + R9 290 + 8GB DDR3 1333 :: I3-540 @ 4.2 GHZ + 6870 4GB DDR3 2000 :: E6300 @ 2.7 GHZ + 1950XTX 2GB DDR2 800 :: A64 3700 + 1950PRO AGP 2GB DDR400 :: K63+ @ 550MHZ + V2 SLI 256 PC133:: P200 + MYSTIQUE / 3Dfx 128 PC66
Reply 16 of 19, by DamienC
There were some 233MHz MMX Pentiums on eBay for $10 each so I picked one up. MW2 runs MUCH better. Definitely not 60fps, probably in the ballpark of ~30-40 fps. That's good enough for me. The game is definitely playable at 640x480 now.
I have no desire to do any sort of 3D acceleration with this machine; this is purely a DOS gaming box. I might throw together a Pentium II build with a Voodoo card of some sort in the future for the small stack of 95/98 games I have that are annoying to get running on a XP/7/10 machine.
Reply 17 of 19, by clueless1
Yeah, I think our performance perceptions in the moment are much different than in retrospect. I'm playing System Shock in 640x480 right now on a Pentium 120 @ 133Mhz and it can get pretty sluggish. But when I originally played SS1, it was on a 486 DX4 100 and I don't remember 640x480 feeling sluggish at all. Same with Descent, Descent2 and Duke3D. All feel sluggish now on this P133 but back in the day, I played them either on the DX4 100 or a Pentium 133 and I thought they were performing awesomely. 😀
Reply 18 of 19, by F2bnp
Just tried 1024x768 on a Tualatin 1.4 and I didn't expect it to be this slow. I don't think it ever exceeds 30fps no matter what. I didn't remember it being this slow on a Tualatin 😵 .
Reply 19 of 19, by gdjacobs
Voodoo cards were pretty much the only accelerators (that I know of) which were designed for and worked on DOS games under DOS. Voodoo 2 and later could sometimes be cajoled to work, but Voodoo 1 is natively supported by most if not all 3d accelerated DOS games.
So, you can do 3d acceleration under DOS if you like.
