Great Hierophant wrote:Why would use CuteMouse within DOSBox? DOSBox already provides its own built-in mouse driver.
It doesn't appear to work when you're booting from an image and bypassing the built-in DOS shell.
When using the built-in shell/utilities boot, the mouse works flawlessly.
In TANDY mode, when booting from MS-DOS 6.22 or 3.2, microsoft mouse driver detects nothing and ctmouse detects a PS/2 mouse but it's nonfunctional; there's no mouse movement in Edit, Qbasic, or Conquest of Camelot. Forcing serial mode changes nothing.
In SVGA_S3 mode, when booting from MS-DOS 6.22, the microsoft serial mouse driver works fine, ctmouse still finds a PS/2 mouse but it's non-functional.
Most tandy systems used a serial microsoft mouse as far as I ever saw; this is either broken in DOSBOX or it's attempting to default to the weird tandy joystick mouse thing which almost nobody used.
How can I get TANDY mode to recognize a serial mouse?
