First post, by mzry
Heya,
On one of my P2 systems I had to bend all of the PCI brackets for them to slot in properly because the mobo was too low down. On a P3 mobo in the same case the PCI slots don't need any adjusting. Is this normal?
Thx
Heya,
Thx
Hmm... would this depend on the case you're using and the size of the stand-offs you're using?
I agree with brassicgamer, probably an issue with the standoff height. They come in more than one size:
https://upload.wikimedia.org/wikipedia/common … IMGP5029_wp.jpg
1982 to 2001
wrote:Hmm... would this depend on the case you're using and the size of the stand-offs you're using?
Mm. Can also imagine newer boards might have more layers, and the laminate generally become somewhat thicker.
Perhaps it could be offset with washers between the standoffs and the board?
No these things aren't standardized, and different cases use different height stand-offs. Why wouldn't this be defined in the ATX standard?
"This all reminds me when i took the windows vista sticker thingy off my old laptop, and on my washing machine as a joke. A few days later said washing machine stopped working. I still think this cannot be a coincidence."
Thanks for the replies, I'll see if I can get taller stand offs.
