DInotopia
First post, by jarlax
im a noob to dosbox, but wanted to run dinotopia, dosbox is set to the default configuration i have a pentium 3 processor(750), run windows 98,
every time i try and run the game the below error pops up: the supporting scren to Dosbox says illigal read illigal write so fast i can barely read it.
i can barely read code so that makes no sence to me.
any suggestions?
    21.69 KiB
Reply 4 of 5, by jarlax
i tried to setsound correctly, but it cant detect any digital sound driver (you only have 1-2 choices) and it wont let me run without a digital sound driver.
should i try the manual config for a sound driver or leave it with the defalt settings at installation? will it matter since Dosbox will emulate it anyway?
