First post, by kiwa
Hi!
anyone can help me with this? i found my old Disney sound source device, only the actual dac part, not the speaker part. for what i have found online i could use 3 pins to connect this to a amp, 5v and gnd. but i don't know with cable does what.
Anyone have any information about this?
Thanks.
Reply 1 of 7, by Jo22
Oh, that's simple (in theory). Just get a datasheet of the DAC and follow the traces. 😉
If you have got an ohm meter or a multi meter, you can also check which trace or wire has contact with the IC's power pin.
Normally, red an black should be for plus and minus. And yellow/green for the amp/speaker part.
But I'm speaking under correction. I don't own a Speech Thing myself and so this just pure guessing.
So it's probably better to wait until a Speech Thing owner will answer you question.
And I also think it's better to try with passive head phones first, before connecting a speaker or an amp - sometimes the power of such a DAC is sufficient to drive sensitive head phones (depending on the impedance and other factors of the DAC and the head phones).
Good luck! 😀
Reply 2 of 7, by keropi
there is more to it in the Disney Sound Source speaker part as it is self-powered with a 9v battery:
I'd say your best bet is to use a multimeter to isolate the 5v wire and not use it at all. Then attach a passive speaker/headphones and try to find the pair that carries the audio. If you need to build an amp then use an external power source like the original design, over-drawing current from the LPT is not a good idea...
🎵 🎧 SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 3 of 7, by Great Hierophant
The whole Sound Source, parallel port dongle and speaker, is powered by the battery. The four lines represent power, GND, audio out and status LED. The parallel port was not intended to provide a source of current. The schematic in the Sound Source Programmer's Guide would confirm this. One thing the schematic does not tell you is whether the power to the IC is +5v or +9v.
Reply 4 of 7, by gdjacobs
Rail voltage should be discernible by pulling a spec sheet for the IC, so that shouldn't pose a challenge.
Reply 5 of 7, by kiwa
Thanks for the info everyone!, i can't find the datasheet, probably because is some random custom part from that time, i did found the programmer guide, that says that there are 4 pins in the cable and gave me the same info that keropi said, power, gnd, sound and "Power Control" that turns on the amplifier.
keropi wrote:
there is more to it in the Disney Sound Source speaker part as it is self-powered with a 9v battery: […]
I think i can do something with the photos! thanks!
Reply 6 of 7, by kiwa
I got it working! really nice, thanks for the info guys.
Reply 7 of 7, by Blzut3
Apologies for the necrobump, but this thread is pretty much what comes up in searches for the pinout for the Disney Sound Source so seems best to add onto it.
Since kiwa appears to have resoldered the wires the color changes made the above slightly unclear. Between this and the reverse engineered schematics of the power supply/amplifier module at https://github.com/roybaer/sound_source I was able to successfully make an adapter from an RJ11 screw terminal to 1/8" jack. The pinout for the jack is pin 1 (yellow) = line out, pin 2 (green) = ground, pin 3 (red) = +9v(/+5v?), pin 4 (black) = select. As per above you can ignore the select line, but it was the select line (pin 17) of the parallel port fed into transistors to turn on the +9v line.
If one doesn't trust the pin numbering, ground can be identified by direct continuity to the shell of the DSS. The +v line is the adjacent center pin, and the line out is the adjacent outer pin.
In regards to +9v vs +5v, it would appear that the power supply/amplifier directly fed +9v after the transistor and diode. Perhaps it works with either?
