First post, by SRQ
I found out that I happened to have a spare board that fits an OEM system with a riser in my last load of parts. Super goddamn lucky. With my 486 VLB board waiting on more cache, I want to put it together.
Questions!
The onboard is an S3 Trio32, I don't have anything else pre-1995. Is it like, /super/ slower than a 64? Or "Still more than enough for Doom II"
I want to run a Pentium 100. I have a 133, and a 75. Should I underclock the 133 or overclock the 75? Could either be run without a fan (large heat sink though.)
This board appears to have no cache and, oddly, came with an MMX 200- despite being socket 5 with a 1994. I found this really odd- but it boots with it. Weird since I thought the MMX series didn't work with S5.
E: Double odd? It has a turbo jumper. No idea if it works, but that means this was an MMX system with turbo!
